Strange ringing-like artifacts in print
jwx23
(@jwx23)
Hello all,
I am having some trouble with my printer creating these strange artifacts up the z-axis walls if the walls are detailed. Conversely, if the print has smooth walls or not very detailed walls, then the walls print just fine. Attached is an image showing what I am talking about with the axes labeled. I have tried printing at different temperatures and slowing the speed down to 55% all with the same result. Could I have an issue with my belts being loose or low lubrication on my bearings?
Thanks
Opublikowany : 26/06/2017 9:55 pm
