Spitfire Printing
david.k21
(@david-k21)
Spitfire Printing
I know there already a few topics with print issues on the spitfire but i couldn't find anyone with the same issue i have. I think its over extrusion but wanted more opinions. I tried this print with the PLA from Prusa and with PLA from inland (pictured) and had the exact same results. Do you think its okay to just carefully knock them off with a razor blade and sand with super fine sandpaper? or should i adjust the settings?
Veröffentlicht : 08/06/2017 9:59 pm
David T.
(@david-t)
Re: Spitfire Printing
It's not overextrusion. It's result of oozing caused by high print temperature and low retraction combined with printing of more than one object on buildplate (long moves). You might try to use a bit lower temperature or add a little of cooling fan (like 30%).
Trimming by razor blade is quite safe, just don't damage the surface of the wing.
Veröffentlicht : 08/06/2017 11:23 pm
