Some Firmware 3.0.3 bug
Hi everyone!
I have found some bug in the firmware 3.0.3 .
1# When you enter in a dir in your SD for go back the option is labeled "Lingua" 😀 😀 (in english language system)
2# When i start printing ,printer pass 3 step : print a line , calibrate ,then print another line from the gcode. It' possible disable the line printing before the autocalibration ?
3# When I start printing from SD the temperature regards nozzle (with Simplify3D) is set to 0 ! Everytime i should change the temperature to reach manually .
Tnx for every help!! Best machine 😀
p.s what is ZHop profile in Slic3r option
Respondido : 18/06/2016 10:29 am
