Simplify3D rafts not working
HumpbackHeart Studios
(@humpbackheart-studios)
Using the Prusa supplied S3D profile, when I try to print with a raft at any layer height, the printer will do it's leveling routine, prime the nozzle at the front of the bed just fine, then raise probably 5-10mm and start trying to print in thin air.
If I turn off raft and leave all other settings the same, the print works fine.
Any ideas?
Opublikowany : 18/11/2016 2:03 am
