Simplify3D and Cooling Fan Problems Anyone?
Hi all,
Running S3D with the RC4fff that Josef has posted. Occasionally the parts cooling fan will no long come on and it is not a hardware issue since I can start it via the printer menu.
I can look at the gcode and find that the M106 line is missing. The most recent time this has happened however I found that it was inserting the line at layer two but as "M126 S255".
The only way I have been able to correct this is to delete the profile and reload it then everything is back to normal for a while. This has been an ongoing problem.
S3D claims I am making changes to the profile that cause this and I shouldn't change anything. This doesn't even begin to make sense. According to them we should never make any changes or else bad things will happen.
Thanks for any thoughts on this.
