Serious firmware update failures!!
louise.o
(@louise-o)
Can anybody offer a solution to this firmware failure message?
I Flashed correct 1.75 mm _MK......v6full.hex
Correct COM
RESULT
averdude.exe: stk500v2_ReceivedMessage() timeout
averdude.exe: stk500v2_getsync() timeout communicating with programmer avrdude.exe done thank you
Has anybody else experienced this problem when updating firmware? Used firmware updated v2
Shut everything down both computer and printer them rebooted and tried again. Same result. Tried. one more time, same deal.
Any thoughts appreciated.
Respondido : 18/10/2017 11:01 pm
Olef
 Olef
(@olef)
Re: Serious firmware update failures!!
Try different USB cable in different port on your PC perhaps?
Respondido : 19/10/2017 1:51 am
louise.o
(@louise-o)
Droid just that with same result.
Respondido : 19/10/2017 5:28 am
Olef
 Olef
(@olef)
Silly question - you are not also connected to the printer by Pronterface or Octoprint when trying to flash perhaps? Something is stopping the updater communicating with the board.
Respondido : 19/10/2017 8:52 am
3d-gussner
(@3d-gussner)
Reputable Member Prusa-Translations
Correct COM
RESULT
Hi Louise,
which OS do you use? Can you connect via Pronterface/Octoprint or another computer to the printer? Try to shutdown the printer, unplug the USB cable, power on the printer and plug in the usb cable again? Before trying to upload firmware make sure that a serial communication is working, Pronterface is a part of the Prusa Drivers install package.
Hope that helps.
Respondido : 19/10/2017 9:02 am
IKER ERAUSKIN
(@iker-erauskin)
I know that you are telling that you are using correct COM, but sorry to insist... if you are using windows, do you check in configurations, device manager, universal serial bus controllers.... really witch COM is using? I suppose that you already check but... 😉
Respondido : 19/10/2017 10:09 am
