Self test ok message in the middle of a print and loss of calibration settings
timothy.b2
(@timothy-b2)
Hi all,
Having a problem with a the printer loosing its calibration when its switch off. Once the calibration is set and I have received the message saying that the calibration is successful, I can print for hours with no problems but once it is switched off and cools and I switch it on again I get the clean nozzle waiting for reset message, when I start a new print. If I then re-run the calibration routine it works fine most of the time. Twice however I have received a self test ok message in the middle of the print, which requires a reset.
I am running the 3.0.10 firmware and I purchased the kit not the assembled machine. Any advice would be much appreciated.
regards
Tim
Napsal : 05/06/2017 12:00 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Self test ok message in the middle of a print and loss of calibration settings
You need to print the V2Calibration G-Code and allow it to finish.
This will turn off the calibration required message.
Peter
Napsal : 05/06/2017 12:18 pm
JeffJordan
(@jeffjordan)
Member Moderator
... Any advice would be much appreciated....
use this forum as a database for information ! not nescessary to point out the search function....
read and learn about our i3 MK2(S). read in old threads (there are a lot of them with very useful information inside) and assume that other people had the same teething troubles as well.
Napsal : 05/06/2017 12:52 pm
timothy.b2
(@timothy-b2)
Upgraded the firmware to 3.0.11, and all problems have since disappeared.
Napsal : 18/06/2017 1:59 pm
