RAMBo Mini - 12v out?
TheCase
(@thecase)
I'm wanting to put some LED lighting on my new rig. Is there an open 12V out on the board?
Opublikowany : 01/06/2016 3:51 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: RAMBo Mini - 12v out?
Hi Bryan
The 5V pinouts are here: http://reprap.org/wiki/MiniRambo_development and there will be points on the board where you can draw 12V (see the picture up one level on the link).
But I would suggest that it better to take a power feed for add-ons direct from the PSU as this will definately not cause any damage to a rather expensive RAMBo board. You can use a buck/boost regulator from eBay if you require other than the 12V. Best to confirm the voltage of the PSU output first.
Peter
Opublikowany : 01/06/2016 9:54 am
TheCase
(@thecase)
Yeah - good call. I'll go direct from the power supply for 12v.
Opublikowany : 01/06/2016 5:45 pm
