Prusa MK2 kit died during calibration XYZ
federico.m3
(@federico-m3)
Hello guys,
Sorry to bother, i ve just finished assembly my ORIGINAL PRUSA MK2 kit. I was doing the selfcalibration and the 2 fan worked fine, when the printer started the X Y Z calibration i saw a red light somewhere and it turned off. Now i plug it but nothing happens, LCD is dead and so the printer. I checked the cable connection thousand of times but everything seems fine. The voltage is 110 on the PSU since i am in Taiwan. I really cannot find anything wrong. Someone have any suggestions?
Napsal : 24/05/2017 5:26 pm
federico.m3
(@federico-m3)
Re: Prusa MK2 kit died during calibration XYZ
I found the problem, i switched the heatbed with the nozzle hotend output...is the electonics burnt?
Napsal : 24/05/2017 5:40 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
First things to check are the fuses. There's one on the power socket and 3 on the RAMBo.
Check all 4 and if one has blown, post back here letting us know which one.
Peter
EDIT: Ok, so it will be one of the two 5Amp fuses on hte RAMBo.
