Problems with first layer
ľuboslava.k2
(@luboslava-k2)
Hi, I have problem with my MK2S. Every time when I start printing and I am printing bigger area of first layer always happen what is on picture. (really rough surface and some areas don't stick properly.) Can you please help me ? I tried to move with Z-axis in both direction but it didn't do any better. What can possible be a problem ? Maybe extrusion rate isn't right ? Thanks for answers.
attachment=0]22291040_10212204802529629_726035378_o.jpg[/attachment]
Opublikowany : 05/10/2017 11:10 pm
Milhooz
(@milhooz)
Re: Problems with first layer
Difficult to say, the photo is a bit blurry and I don't know how many layers do you have here. Did you calibrate your Z height? Did you wipe the surface with alcohol? The prime ring looks very thick. Which material is this? What is sure is that is not normal.
Opublikowany : 06/10/2017 12:27 am
AJS
 AJS
(@ajs)
Please try these step:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
and post your results so we can help.
Opublikowany : 06/10/2017 3:16 am
