Problem y axis Calibration
dt
 dt
(@dt)
Hi
My english is very bad, so I take the translator, Sorry
I have put together a new Pruska i3 mk2 kit and have the following
I have the following problem when setting the y axis. I can only set forward and not backward.
At the x and z axis, I can in both directions.
When going back, "the clacking", very quiet and fine as he would make microsteps, you see nothing.
https://www.dropbox.com/s/2otaqidnuqfjh0g/VID_20170223_073059.mp4?dl=0
In the worst case, it also fails on the y axis
https://www.dropbox.com/s/a6c6mylbj7d0bou/VID_20170222_232637.mp4?dl=0
If I change the connector to the electronic of y axis and z axis, the y axis and the z axis has this symptom, so the motor is good.
Have already read, it could be a PINDA problem, one can measure the sensor me a simple multimeter?
Thank you very much for your help
Postato : 23/02/2017 8:33 am
dt
 dt
(@dt)
Re: Problem y axis Calibration
Sorry!!!
Y axis and X axis
it should mean
Postato : 23/02/2017 8:44 am
dt
 dt
(@dt)
Come again
I was able to do a self-test this morning, with an open electronics box and had previously pinda and limit switch disconnected and plugged in again. 😀
Box closed again and the error is back 👿
Now I'll measure the limit switch times cable and plug and check, with the Pinda connector, measuring cables becomes difficult
Postato : 23/02/2017 11:02 am
dt
 dt
(@dt)
The printer is working :mrgreen:
The limit switch was defective.
I opened it and adjusted it and glued it with hot glue.
Postato : 23/02/2017 6:30 pm
Postato : 23/02/2017 11:27 pm
