Problem with Y-Carriage
marco.c2
(@marco-c2)
Hi, i found that the holes on the Y-Carriage are a little too big for M3x12 screw. I'm doing something wrong or i have a kit problem?
Thanks a lot
Marco
Opublikowany : 23/07/2016 9:25 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Problem with Y-Carriage
Marco
I think that when you go further in the build, you will find that the screws simply pass through the frame and screw into inserts in the bed.
Peter
Opublikowany : 23/07/2016 10:43 am
marco.c2
(@marco-c2)
Thank you very much.
I have read all the rest of assembly instruction and found that.
Opublikowany : 23/07/2016 6:43 pm
