Problem with upgrading MK2 to FW 3.1.0
stibi
(@stibi)
today I tried to upgrade firmware on my MK2 to the latest 3.1.0 version. I'm on Linux, so the same as before, I used avrdude:
$ pwd
/home/stibi/Downloads/prusa_firmware/prusa3d_fw_3_1_0/MK2
$ sudo avrdude -c stk500v2 -b 115200 -p Atmega2560 -v -P /dev/ttyACM0 -D -U 1_75mm_MK2-RAMBo13a-E3Dv6full.hex
avrdude: Version 6.3, compiled on Aug 9 2017 at 12:31:56
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : stk500v2
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel STK500 Version 2.x firmware
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: safemode: hfuse reads as D0
avrdude: safemode: efuse reads as FD
avrdude: reading input file "1_75mm_MK2-RAMBo13a-E3Dv6full.hex"
avrdude: input file 1_75mm_MK2-RAMBo13a-E3Dv6full.hex auto detected as Intel Hex
avrdude: writing flash (241578 bytes):
Writing | ############################### | 62% 24.01savrdude: stk500v2_ReceiveMessage(): timeout
Writing | ################################# | 66% 30.53savrdude: stk500v2_ReceiveMessage(): timeout
Writing | ############################################ | 87% 43.62savrdude: stk500v2_ReceiveMessage(): timeout
Writing | ################################################## | 100% 53.61s
avrdude: 241578 bytes of flash written
avrdude: verifying flash memory against 1_75mm_MK2-RAMBo13a-E3Dv6full.hex:
avrdude: load data flash data from input file 1_75mm_MK2-RAMBo13a-E3Dv6full.hex:
avrdude: input file 1_75mm_MK2-RAMBo13a-E3Dv6full.hex contains 241578 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 29.62s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x24b00
0xff != 0xdc
avrdude: verification error; content mismatch
avrdude: safemode: Fuses OK (E:FD, H:D0, L:FF)
avrdude done. Thank you.
😯 oops…what I did wrong? Is the command and its parameters correct?
The printer is of course not working now, I can't upload older version. I hope it's not bricked…
Now I'm googling how to fix it, but if you have a clue, please help.
I kind of remember that there was something about avrdude version? The latest might now be compatible to do this task? Is it possible?
Napsal : 29/11/2017 12:46 pm
stibi
(@stibi)
Re: Problem with upgrading MK2 to FW 3.1.0
Hi guys,
sorry for bumping the post, but really no hint at all what could be wrong here?
Napsal : 04/12/2017 10:56 am
Inglebard
(@inglebard)
Hi, first of all, I'm not an expert.
I recently upgrade my printer without issue. But before doing that, I read a lot of posts about problem / how to.
And I see during your update timeout error. If I remember well, it can be cause of a too long usb cable (+1.5m) or poor quality usb cable.
Napsal : 04/12/2017 10:52 pm
stibi
(@stibi)
Hi, thanks for your reply!
I'm pretty sure the cable is ok, it's the original cable, bundled to the printer.
Anyway, I just tried the FirmwareUpdater app for Windows and it worked! Wife's Windows notebook saved me 🙂
So, the printer works now, but still I'd like to know what is the problem with linux and avrdude…if anyone knows, please let me know.
Napsal : 05/12/2017 5:29 pm
Inglebard
(@inglebard)
I am on linux too (Archlinux).
I have no issue with avrdude version 6.3.
Napsal : 06/12/2017 11:13 am
Sherri
(@sherri)
Did the OP solve this problem? I'm having trouble getting my Ubuntu to communicate with my MK2 also. I'm running avrdude 6.2 on Ubuntu 16.04. I ended up using a Windows PC to flash 3.1.0 to the printer previously and have been trying to flash a previous version of FW to the printer via my Ubuntu computer. Is there a chance I could "brick" the printer?!!!
Napsal : 18/12/2017 9:24 pm
Sherri
(@sherri)
FWIW... I can confirm mine is working on Ubuntu 16.04, but I flashed an older version. My printer had 3.1.0 at the time so it was communicating with avrdude just fine. Looks to me like a few little hiccups with the timeouts and then resumed saving. USB cable, close proximity to mains electric lines, RF interference? I would think you could just try again? Or won't it communicate at all?
Napsal : 20/12/2017 2:29 am
