Problem with calibration and x axis
norman.k
(@norman-k)
Hello!
I have a problem with my mk2and i hope i will find some answers here.
I managed do build the kit and printed some models.
In the last model i had a gap in the x axis after updating the firmware.
Now the printer head crashes into the side of the endstop in the x axis when calibrating with a ratling sound. When testing the endstop in the selftest mode, the reacts to manually pressing the endstop, when i push the printerhead manually against the enstop i hear a clic.
So why does it occur (it never happens before) and can I calibrate the x axis?
Greetings Norman
Napsal : 19/09/2016 12:18 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Problem with calibration and x axis
Norman
Ensure that the cabling from the rear of the extruder is not getting in the way of the movement.
Peter
Napsal : 19/09/2016 9:14 am
