Prints aren't turning out to be that great in spots
Jonathan Larsen
(@jonathan-larsen)
Why aren't all the areas being completely filled in?? These area's are only the starting of the prints too. The rest of the print looks whole and great!
I'm using a .3mm stainless steel nozzle, these prints had 25% infill with inside being honeycomb and outside being concentric.
Posted : 07/02/2017 8:22 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Prints aren't turning out to be that great in spots
try to increase the outline overlap and reduce printing speed.
have a look here
in slic3r you'll find this setting at <print settings> -> <advanced> -> <overlap>.
furthermore i would recommend to reduce the infill threshold area (set it to 0) or when using simplify 3d the minimal infill length.
Posted : 07/02/2017 8:54 pm
Jonathan Larsen
(@jonathan-larsen)
Thank you so much Jeff. I will give all of that a try!
Posted : 07/02/2017 10:02 pm
