Printing not sticking
alex.s10
(@alex-s10)
My printer is printing PLA and using its default PLA settings. When I start a print the initial print line works then the object I try making, the PLA doesn't stick to my bed. I just cleaned it and it also is giving me a issue saying the nozzle is not set with relationship to the bed, which i cannot figure out how to make go away.
Opublikowany : 23/07/2017 11:45 pm
solomon.c
(@solomon-c)
Re: Printing not sticking
If you've done the steps identified in this video, then I don't know what the issue would be. If you haven't, then perhaps they will help. (It's the intro video on how to check all the calibration stuff.)
Opublikowany : 24/07/2017 2:11 am
AJS
 AJS
(@ajs)
You need to calibrate the Z offset (the distance from the PINDA sensor to the tip of the nozzle.
Please read the tread "Life Adjust Z - my way" over in the calibration section. Read until you see V4 of the calibration code.
Opublikowany : 24/07/2017 5:04 am
