Printing issues
Ben Hartman
(@ben-hartman)
Printing issues
So my printer is making weird grinding noises during printing now which has been making the print mess up and start printing to the side of what it was printing. Im also seeing and ! on the LCD then sometime a $4 which I dont know what any of that means but I havent had my printer for very long and I just need it to work.
Opublikowany : 22/11/2017 12:14 am
AJS
 AJS
(@ajs)
Re: Printing issues
ben.h10,
You will need to be much more descriptive if you want us to help you solve your problem. You are our eyes and ears. We can't see what you do. Include a photo or two.
It sounds like something is catching and causing X or Y to slip (which might damage the belts if it keeps happening).
Common causes to check can be found here:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Opublikowany : 23/11/2017 2:14 am
