Printing 3DBenchy
Mao
 Mao
(@mao)
Printing 3DBenchy
I got my printer kit last Wednesday and got it printing yesterday. Today I printed 3DBechy test print in 3 hours and 16 minutes. After removing the support structures the boat seemed to be quite fine. See pictures!
Opublikowany : 04/02/2017 1:27 pm
David T.
(@david-t)
Re: Printing 3DBenchy
3Dbenchy should come out well without supports, that's why the model is designed the way it is designed - to test capabilities of the printer.
Opublikowany : 04/02/2017 1:37 pm
JeffJordan
(@jeffjordan)
Member Moderator
hi martti,
➡ i would recommend to check out philipp's settings for the 3d-benchy.
these settings deliver astonishing quality (even @ 200µm).
Opublikowany : 04/02/2017 3:20 pm
Mao
 Mao
(@mao)
It printed well without supports about an hour faster. 🙂
Opublikowany : 05/02/2017 12:01 pm
Knickohr
(@knickohr)
Member Moderator
I also print the 3DBenchy 🙂
Without supports and brim. I got some warping in the left front side.
(silver PLA from Prusa)
Thomas
Opublikowany : 05/02/2017 9:27 pm
Knickohr
(@knickohr)
Member Moderator
I printed de Benchy in different layer heights. Interesting results :
Look at the banding in the lower boat hull !
I also recognized much less stringing and better bridges in the 0.20mm layer height.
There are some more pictures. If you're interested I will it upload too.
Thomas
Opublikowany : 06/02/2017 9:07 pm
