Printer Stops extruding mid Print
laurin.g
(@laurin-g)
Hi, im having troubles lately with my printer and im running out of ideas
Printing with fillamentum PETG at 240/90
Problem:
Printer stops extruding mid print. It seems to happen when the layer print duration decreases rapidly/when the printspeed is reduced to keep the part cool enough.
The extruder gear grinds a gap in the filament while It tries to extrude.
This does not always happen on the exact same layer but its not random (pictures should proove that)
I replaced the following parts:
nozzle, heater cartridge, Heatbreak screw inside E3D Hotend, PTFE Tube and the extruder Gear
I also tried disabling retraction but it didnt do any difference.
One of the pictures belows shows the end of filament after unloading it. It seems that the last part has a slightly larger diameter as it was already heated a bit. This could be the reason as after loading filament again the printer extrudes just fine.
IMPORTANT:
My printer lives in an enclosure and was working fine for several months. The temperature inside the enclosure is around 45°C
The printers behaviour seems to depend on the surrounding temperature: When the enclosure door is opened, most of the prints go well.
I already installed a fan to my enclosure but Id like to find the source of the problem rather than to minimize the number of failed prints.
The resulting failed prints can be seen in the pictures (it happens stls independent)
Thanks for your help
Publié : 08/06/2017 6:58 pm
laurin.g
(@laurin-g)
Re: Printer Stops extruding mid Print
More images Below
Publié : 08/06/2017 7:00 pm
Lonney Ferguson
(@lonney-ferguson)
I also have this same exact issue. I am able to print PLA with no issues, but when it comes to PETG I have no success. The photos that laurin.g posted match my results exactly also. Is there any suggestions to resolve this issue. Very frustrating.
Publié : 24/08/2017 5:23 pm
christopher.k11
(@christopher-k11)
I have the same issue. I upgraded to the Mk2.5 thinking that might work. I still can’t get a good print out of this thing. Very disappointed with the whole experience.
Has anyone found a solution?
Publié : 30/06/2018 4:18 am
