Printer skipping (Mk2s)
ben.h8
(@ben-h8)
Hi everyone,
I got my Mk2s about 2 months ago and it has been printing very well with eSun PETG (red). About a week ago I changed to Hatchbox PETG (gold) and the failure rate went up significantly. I thought it might just be differences in the filament itself so I did some more tuning and then it printed an 8-hour piece pretty much perfectly. The next piece, however, it stopped extruding in the middle of the print. When I tried again it would intermittently stop extruding and then begin again, seemingly at random, which obviously ruins the print. Since about 3 days ago I have not been able to print anything successfully due to this problem. This is what I have tried:
1. I thought it was a clogged nozzle, so I cleaned the nozzle (using the needle from the kit) and checked the flow when using Load Filament. Assuming filament does go through, the flow is steady and straight, so I don't think the nozzle is clogged.
2. I unloaded and reloaded the filament. When unloading, the motor turns but is unable to push the filament out and I had to repeat it a few times and apply tension upward to get the filament out. I cut the filament a few centimeters above the end and reloaded the filament and this time it went through perfectly. I don't think the extruder motor is the problem.
3. I checked the hobbed pulley to see if it were dirty and preventing the teeth from gripping the filament. The pulley had some debris, but not a lot and it is clean now.
4. I loosened the spring screws on the side of the extruder housing to see if they were too tight and preventing extrusion. This actually made it worse. I then tightened the screws and this improved it, but only temporarily. I also increased the flow in the printer to 151% and that seemed to help, but again only temporarily.
Can anyone advise? This is very frustrating and I am worried something important is broken.
Napsal : 31/08/2017 7:20 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Printer skipping (Mk2s)
sounds for me as if one of your wires is broken and at a certain position (or height) interrupts the extruder stepper to work properly.
or one of your connectors has gone loose at the rambo.
but there might be a lot of other possibilities too:
at which ambient temperature are you printing ?
do you print inside an encolosure.
is your extruder fan (the one at the left side) working properly ?
what are your slicer settings (retraction > 0.8mm ?) ?
do you get the same problems when printing objects from the genuine sd-card ?
is your filament spool running free, or is there any blockage at a certain position ?
do you still use the genuine spool holder ?
Napsal : 31/08/2017 8:43 pm
ben.h8
(@ben-h8)
Thanks for the response. Here are my answers:
1. Ambient temperature is circa 25 degrees Celsius.
2. No enclosure.
3. Both fans are running, as far as I can tell (the larger fan only turns on after the wipe, but afterwards it is running).
4. I have a 2 mm retraction at 50 mm/s with a z-life of 0.5 mm. I wanted more retraction because PETG strings a lot, but I also didn't want too much for fear of pulling hot filament into the non-heated part of the nozzle.
5. I have not had any issues printing the Prusa logo or the frog from PLA. My prints using red eSun PETG for ~1 month were also not a problem. This problem began about 3 days ago with Hatchbox gold PETG.
6. The spool can rotate freely.
7. I am still using the 2-sided spool holder from the kit.
If it were a wire connection issue, how would I check that?
Napsal : 31/08/2017 8:53 pm
ben.h8
(@ben-h8)
Ok so after some more investigation I think I have found a potential answer. I opened the extruder housing again by removing the 2 spring screws and rotating the piece down to reveal the hobbed pulley. This time the hole where the tightening screw was became visible and I found no screw there:
I assume this means the extruder motor is turning, but the pulley is not and therefore cannot push/pull the filament. What can I do about this? Can I get a replacement screw from Prusa?
EDIT: apparently the image tag isn't working so the link is: http://imgur.com/aNaQDyn
Napsal : 01/09/2017 4:57 am
AJS
 AJS
(@ajs)
Yes. That would cause the problem.
This is a standard set screw (sometimes called a grub screw). You should be able to find it at a local hardware store.
But the Prusa on-line support should be able to tell you the size.
Napsal : 01/09/2017 5:25 am
