Printer random y axis travel during print please help
Hello everyone, i would like to start with i have had my prusa I3 MK2s for a month now.
assembled my self and have had great prints for about 3 weeks.
than all of a sudden on any print since my y axis travels all the way to the front then the back of y axis several times then goes back to printing.
printer does not do this at same percentage complete even on same print repeated seems random.
i have tried many prints from multiple memory cards.
removed and reconnected all wiring.
reran calibration every thing comes out fine.
please im not sure what could be the problem.
thank you, any advice would be appreciated.
Re: Printer random y axis travel during print please help
Wow that's weird! Do you have the same issue with the gcode provided with the printer?
Which is your firmwares version?
Have you tried a full reset and flash again the firmware?
i just did a full reset then flashed firmware 1_75mm_MK2-RAMBo13a-E3Dv6full.hex and ran xyz calibration.
tryed printing benchy that was supplied with my printer.
still same issue.
That is a wild video. Very strange. Since it is doing it after a factory reset, and with supplied .gcode, it must be a hardware issue (RAMBO) If you have checked all connectors, I would contact PRUSA.
