Print way off vertical?
Danlad1631
(@danlad1631)
So I printed a model that is 160mm tall and as you can see in the attached image, the cylinder is way off vertical. What's causing that and how can I fix it?
Thanks
Postato : 27/03/2017 1:16 pm
David T.
(@david-t)
Re: Print way off vertical?
Is the cylinder leaning forward or back? If yes, check perpendicularity of Y and Z axis of the frame.
Postato : 27/03/2017 3:25 pm
Danlad1631
(@danlad1631)
Sorry for the delayed response. The print is leaning back.
The bed is flat but the frame is leaning back, how do I correct this?
Postato : 05/04/2017 6:58 pm
Starlynk
(@starlynk)
Check the connection points of the y axis to the frame. Make sure it is fully seated in the frame and the frame is not touching the table. It should be elevated by the y axis. Also, check that the frame is in between the 2 washers. If it's not, it could be the problem.
Postato : 05/04/2017 8:10 pm
David T.
(@david-t)
Check distance mentioned in http://manual.prusa3d.com/Guide/2.+Y-axis+assembly/104 Step 11 and check if you correctly mounted PSU according http://manual.prusa3d.com/Guide/7.+PSU+%26+Heatbed+assembly/109 Step 6.
If you do everything right, the frame cannot lean back.
Postato : 05/04/2017 9:02 pm
