Print not straight problem
pawel.p
(@pawel-p)
Hi
I got a problem with my print it used to be OK and I started getting this recently. The sides don't seem to perfect straight and smooth. I assume there is something wrong with Y Axis you can tell by looking at the picture. The X axis sides look very good its the Y axis where it's got this univen effect. Y belt seems to be tight. Anyone any advices I'm new to 3d print.
Postato : 03/09/2017 1:38 pm
AJS
 AJS
(@ajs)
Re: Print not straight problem
This looks to me like a clogged extruder, or bad temperature for the filament.
I don't think the issue is your axis and mechanical movement, but rather the flow from the nozzle "stringing".
I would clean the nozzle (search "cold pull" or run a cleaning filament through it) and see if that improves things.
Postato : 03/09/2017 4:40 pm
