Print layer jumping along x-axis
trevor.b
(@trevor-b)
I'm getting a lot of failed prints due to the extruder jumping anything up to 15mm along the x-axis. I originally thought this might be due to a manifold issue but the gcode looks fine and the failures are at different heights on different print runs.
Looking closer at the belt as a print was running I could see some distortion then looking at the motor pulley the belt was riding up the side flange which has, I guess, caused the belt distortion. I have repositioned the pulley to centralize the belt, however the jumping is continuing. Obviously I have never seen the jump happen so I can't tell for sure that the distorted belt is the cause.
I'm going to have to source a new x-axis belt anyway - I can't see one on the Prusa web site so where's the best place to get one from? Also, is there another potential cause for the jumping that I might have to take into account?
Regards,
Trevor
Veröffentlicht : 17/10/2017 12:19 am
AJS
 AJS
(@ajs)
Re: Print layer jumping along x-axis
See "Print suddenly shifts in X or Y and keeps printing." section of this FAQ post:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Veröffentlicht : 18/10/2017 3:06 am
trevor.b
(@trevor-b)
Thanks for rhe pointer to the FAQ, aaron, a very handy post.
New X-axis belt arrived half an hour ago, I'll fit it and do a complete set of calibrations.
Regards,
Trevor
Veröffentlicht : 18/10/2017 6:21 pm
