[Closed] print going wrong
Alaingeenrits
(@alaingeenrits)
print going wrong
I am using a MK2 with latest firmware and slicing with Slicer from latest driver package. Reinitialized config. I am printing a box in Colorfabb Ngen. Only changed infill to 15%. While printing the base plate the print suddenly goes bad with lots of blobs I guess. Any ideas on the cause? Bad filament? See picture.
Posted : 27/02/2018 1:40 pm
john.b23
(@john-b23)
Re: print going wrong
The appearance of the rest of the print suggests to me that your Z adjustment is too low. The first layer squished out, so the second layer has to squish out too. Eventually you get a glob instead of a line laid down. I'm much less sure of the other part of this answer, which is that the extra drag forced the x or y axis to skip because the amount of resistance to movement was too much for the power the stepper motor could deliver.
Posted : 09/03/2019 9:34 pm
