Print failing
jack.f3
(@jack-f3)
Print failing
This is a brand new pre-assembled Prusa MK2S . I have calibrated to Z and loaded the filament successfully. When I try to print, the temperature never quite stabilizes. It keeps bouncing from around 210 to 220. When it does stabilize, the printer calibrates and starts to print. Nothing comes out but the nozzle leaves an indent on the board. How can I fix it?
Publié : 07/06/2017 7:17 am
jack.f3
(@jack-f3)
Re: Print failing
I went into move Axis and selected extruder and it worked fine. I tried another file ( the preloaded pug) and it failed for the same reason.
Publié : 08/06/2017 3:05 am
