pre-assembled Prusa-V2Calibration.gcode failure
kazem.f
(@kazem-f)
Hello,
I received today my pre-assembled Prusa. I followed the flowchart and "calibrate Z" and instead of printing Prusa logo, I printed V2Calibration (even though this was pre-assembled). I remember the first time it was perfect. In the afternoon, I wanted to show the printer to someone during calibration, so I did calibrate XYZ. Here are the mistakes that I did:
1- I did not read the instructions on the LCD and did not put a paper under the nozzle (I did not hear any loud noise of nozzle hitting the bed, so I hope that is fine)
2- After calibrating 4 points, the printer does another 9. It was taking long and I could not cancel it, so I turned the power off.
After that, I did the prusa logo and I was seeing there is something wrong with the first layer, but I continued. I left the machine during the print and when I came back I saw that the print stuck to the nozzle and it failed the print. I removed the failed print and tried the V2calibration again. This time V2Calibration is not with straight angles. I did "selftest", "Calibrate Z" , "Calibrate XYZ", bed elvel options and they all say it is calibrated. But, with multiple try, I still have problem with "first layer calibration". Please help
Veröffentlicht : 14/09/2017 1:33 am
AJS
 AJS
(@ajs)
Re: pre-assembled Prusa-V2Calibration.gcode failure
You need to let the XYZ calibration finish, and you need to set you Live Z. When you ran the XYZ Calibration it zero-ed your Live Z that the factory had set, and since you did not let it finish, you don't have a calibration of the skew of the printer.
Please follow the step found here:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
All of them. And let them finish. And follow the directions. Failure to do so can damage your printer.
Veröffentlicht : 14/09/2017 6:37 am
