Pinda Probe Nut
cory.w
(@cory-w)
Pinda Probe Nut
I just upgraded my MKS2 with a Titan Extruder. I am using this mount which uses the MK2 pinda probe mount vs. the newer mks2 version https://www.thingiverse.com/thing:2065461 .
My MKS2 kit did not come with the proper nuts to lock the pinda in place. I went to the hardware store to get 5/16 nuts which do not fit. I asked support and the only info i got was 12mm face to face and 6mm diameter. This doesn't help me since we use different sizes in US.
Anyone know what type of nut I need and/or, have a print file to make a replica?
Publié : 22/06/2017 1:40 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Pinda Probe Nut
I think this is what you need: http://www.ebay.com/itm/M8-x-1-25mm-Locking-Flange-Nut-Black-Oxide-Hex-Exhaust-Manifold-Nut-20-pieces-/142419097391?hash=item2128d6f72f:g:KIwAAOSwWxNYnbZz
Peter
Publié : 22/06/2017 10:58 am
richard.l
(@richard-l)
Membre Moderator
Re: Pinda Probe Nut
Cory,
Take your Pinda probe with you to your local Ace Hardware store. They have many sizes of metric screw/nuts/bolts in drawers in the back of my local store. Look for Jam Nuts.
Publié : 22/06/2017 4:44 pm
christophe.p
(@christophe-p)
Membre Moderator
Re: Pinda Probe Nut
You can use my pinda protector which use the proper thread. https://www.thingiverse.com/thing:1617374
Seeing your extruder design, you might have to edit it to reduce the external size, but you'll have something printable as a workaround. I can provide a step file if you prefer.
Anyway having a real nut would be a better solution.
I'm like Jon Snow, I know nothing.
Publié : 22/06/2017 6:16 pm
Alan
 Alan
(@alan)
Re: Pinda Probe Nut
Peter
I suspect the thread will be M8x1 rather than M8x1.25. Barrel sensors like the PINDA probe usually have a fine pitch thread.
Publié : 22/06/2017 6:58 pm
PJR
 PJR
(@pjr)
Re: Pinda Probe Nut
You may well be correct, but my calipers say 1.25mm pitch, but I was measuring in situ and could be very wrong.
Peter
Publié : 22/06/2017 7:28 pm
Re: Pinda Probe Nut
Shame you are so far away, I have 4 spare nuts...
Publié : 22/06/2017 10:20 pm
Alan
 Alan
(@alan)
Re: Pinda Probe Nut
Peter
Same issue with mine, can't get in to measure it. Just going from personal experience a standard metric coarse thread almost never fits a sensor.
Publié : 23/06/2017 9:37 am
christophe.p
(@christophe-p)
Membre Moderator
Re: Pinda Probe Nut
As far as I tested, the closer thread size is ISO M8.1
Publié : 23/06/2017 11:16 am
laila.b
(@laila-b)
Re: Pinda Probe Nut
Anyone ever find the nut size? Mine disappeared the last time I took my printer apart.
THANKS!
Publié : 22/01/2018 8:17 pm
