[Zamknięte] PEI sheet replacement Prusa MK2
henrik.u
(@henrik-u)
My PEI sheet looks like old man who wants go to retire. I have ordered from aliexpress bed stickers and i wonder can i replace pei sheet for that? is there going to be calibration problems after that or what?
This topic was modified 7 years temu by henrik.u
Opublikowany : 25/06/2019 4:40 am
RE: PEI sheet replacement Prusa MK2
The PEI sheets I received from AliExpress are 2 part (adhesive + PEI) so a real pain to apply. I didn't even bother trying.
I've converted to the BuildTak smooth adhesive PEI sheets. They use an easier-to-remove adhesive that will make replacement far less painful. They do leave the notch end uncovered, so watch out for scratching your heated bed surface. I also really like the PrintedSolid spring steel sheet. It's very thin and flexy.
You will have to do a Live-Z calibration when switching between sheets unless they're identical.
Opublikowany : 25/06/2019 3:51 pm
henrik.u
(@henrik-u)
henrik.u
(@henrik-u)
anyone?
Opublikowany : 09/09/2019 3:41 am
