Original i3 MK2 suddenly seems in slow motion
Alex@AgroMe
(@alexagrome)
Today I noticed the printer suddenly very sluggish like if it was in slow motion. It seems to print fine but everything seems like it's in slow motion?
I don't think I have changed any settings in Slic3r nor in the printer but is there a possibility there is a general speed setting somewhere or maybe the power supply is failing (but with steppers I don't think that should affect speed like on a servo for example).
TIA,
Alex
Napsal : 16/03/2018 9:29 pm
Nikolai
(@nikolai)
Re: Original i3 MK2 suddenly seems in slow motion
Check the display if there is still 100% showing.
If yes and it's still very slow, I can recommend to contact the PR live support.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Napsal : 17/03/2018 12:23 am
Alex@AgroMe
(@alexagrome)
Exactly where? When at rest? when printing?
Thanks!
Alex
Napsal : 18/03/2018 3:44 am
rob.l6
(@rob-l6)
I think nikolai means when printing, look at the speed setting.
Also, with a situation like yours I would perform a firmware reset before doing anything else.
I have noticed sometimes that a slower speed is retained on my second print (set from my first), rather than defaulting to 100%. I haven't bothered to look into this any further, but assume it's a firmware bug somewhere.
Napsal : 18/03/2018 6:32 am
Alex@AgroMe
(@alexagrome)
Could be. I was printing some Flex before that which prints at a lower speed, but I have since then power cycled the printer.
I will do the firmware reset and follow up...
Napsal : 20/03/2018 3:08 am
