Nylon help
mike.l5
(@mike-l5)
Nylon help
Hey guys. I just ordered nylon... Talman bridge to be exact. I was just wondering if anyone has tried using nylon and if they could give any recommendations for settings. I know its hydroscopic so I have a bin with descant ready for it.... Just wondering if there is anything I should look for or try in order to get better results.
Any input would be greatly appreciated. Thank you.
Opublikowany : 07/07/2017 5:41 am
JeffJordan
(@jeffjordan)
Member Moderator
Re: Nylon help
even so that I still haven't managed to successfully printed my cheap TW-NL175GN nylon filament, have a look inside this thread. guess there are some useful informations for you.
one idea to make the nylon stick to the pei sheet (which seems to be one of the main problems) is to print a 200µm surface of PETG first, raise the Z live adjustment temporarily and print the nylon on top of the PETG layer (which should stick very well then).
Opublikowany : 07/07/2017 1:52 pm
