Nozzle temp during printing
3DBastler
(@3dbastler)
Today I made my first prints with my preassembled MK2s and run into a question:
My nozzle temp is sweeping during the print round about +/- 3°C.
Is this a normal MK2 behaviour?
Posted : 15/04/2017 6:24 pm
SkynetCH
(@skynetch)
Re: Nozzle temp during printing
I just built my MK2s a few days ago. I'm using a 40mm noctua fan instead of the stock fan and an e3d silicon sock. I have the same behavior my nozzle temp is +/- 3 deg. I guess it's normal.
Posted : 15/04/2017 8:19 pm
JeffJordan
(@jeffjordan)
Member Moderator
with an uncalibrated kit/printer, this is quite normal. but:
you can improve this behaviour by calibrating the pid parameters for the hotend (and the heatbed as well).
have a look at this thread.
afterwards your temperature should be "rock stable" (and way below +/- 1°C deviation during the print).
Posted : 15/04/2017 8:26 pm
SkynetCH
(@skynetch)
Thank you very much for pointing this out ! I was not aware than you can do PID tuning on the prusa as well, going to test it tomorrow ! so far I've only tuned PID loops on my mini racing quads 🙂
Posted : 16/04/2017 1:12 am
3DBastler
(@3dbastler)
I thought that a preassembled one would be calibrated as good as possible
but seems I'm wrong with that idea.
Thx for the link Jeff.
Posted : 16/04/2017 10:50 am
JeffJordan
(@jeffjordan)
Member Moderator
...I thought that a preassembled one would be calibrated as good as possible...this would require an individual calibration for each printer... which will take a few minutes more of time.
and as you know, in business: time is money.
Posted : 16/04/2017 12:13 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Not only that, but this type of calibration needs to be carried out in the environment where the printer will be used. Not really possible.
Peter
Posted : 16/04/2017 12:40 pm
3DBastler
(@3dbastler)
'Problem' solved by following the instructions given inside the link above.
Danke!
Posted : 16/04/2017 4:31 pm
