Nozzle not heating up
caleb.m2
(@caleb-m2)
I recently acquired a Prusia I3 and began to mess with it. However, I noticed that the nozzle was not heating up at all. The hotbed works fine. It just seems to be the nozzle. Any suggestions?
Opublikowany : 25/07/2017 3:29 am
AJS
 AJS
(@ajs)
Re: Nozzle not heating up
Does the self check fail on the nozzle?
Does the printer measure a temp for the nozzle. If you grab the nozzles, does the temp reading go up? (Assuming you are warmer than room temp). If this works, you thermistor is okay.
Check the writing to the extruded, and check the fuse on the Rambo board.
Opublikowany : 25/07/2017 6:53 am
caleb.m2
(@caleb-m2)
Self check runs through fine, and the temperature gage only increases when it is near the hotbed or my hand is on it.
Opublikowany : 25/07/2017 7:25 am
AJS
 AJS
(@ajs)
I am not sure why the self check would complete if the nozzle does not heat...
Check wiring and fuse.
Opublikowany : 28/07/2017 4:12 am
