Ninjaflex pushed out the side of the extruder
I was printing some ninjaflex today, and for my first print, I made some really low stuff and it worked out fine. I started a second longer print and at some point, the material just kinda came out the side of the extruder and just kept loading in that direction. Any idea what I can do to fix this?
Thanks in advance for your time.
Opublikowany : 01/10/2017 2:52 am
Re: Ninjaflex pushed out the side of the extruder
I had a similar issue printing flex. Posts on the forum set me straight. I had retraction set on, that's a no no, or at least reduce the distance of retraction. and my extruder body ended up clogged, along with the nozzle and the filament came out the side of the housing. I'm newbie so would be best if you search on "clogged extruder" for good advice.
Opublikowany : 02/10/2017 8:00 am
