New MK2 : Tree Frog curling
Page 1 / 2
esterne
(@esterne)
Hi there,
I'm new to 3dprinting and was hoping someone can point me in the correct direction.
Received and built my new MK2 kit.
Love the machine.
Prints everything perfectly .... except the tree frog on the supplied SD card.
The batman, whistle, Prusa plate and Marvin all print fine.
The vase is a thing of beauty and sits proudly on my desk.
I've printed other parts not included on the SD and all printed as expected.
Even tried re-generating the gcode in simplify3d with various options tried.
The tree frog is the only print that has failed on me... 👿
While all other prints come out perfectly before and after each failed tree frog attempt.
Eventually I've determined where the point of failure is :
The back of the 2x front legs are curling badly, and eventually the nozzle strikes this curl with varied effects.
I've re-downloaded the latest gcodes from prusa's website, and they do the same.
See photos.
I'm running firmware 3.0.8, everything calibrated and all other prints come out great.
Fan's are working.
Bed is heating.
Just don't know where to start troubleshooting.
Any idea's would be appreciated.
Thanks
Erwin
Posted : 07/09/2016 4:43 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: New MK2 : Tree Frog curling
Usually when I see curling like this, there are 4 possible solutions:
1. Slow down the print
2. Increase cooling
3. Decrease temperature
4. Slice with Z-Lift
However, as this is a pre-sliced model that most of us have printed successfully the solution has to lie elsewhere...
First thing that comes to mind is what filament are you using? The pre-sliced tree frog will usually print fine with Prusa PLA. Other makes of PLA may require lower temperatures. And double-check your fan is blowing onto the part.
Peter
Posted : 07/09/2016 5:46 pm
esterne
(@esterne)
Hi Peter,
I'm using the PLA that came with the kit.
I've tried to slow the print down, via the LCD interface ( 80% ). Could try slower ?
I've also tried turning up the fan to full blast. Didn't really make a difference.
I've also tried re-generating the GCode in simplify3d and played with various options. None successful.
This shouldn't have been necessary as I assume others have printed this successfully with the supplied G-Code.
Also, re-loaded the firmware, and re-downloaded the original samples. Just to be sure.
Also, checked my fan, they are all working.
I'm stumped. 😕
Posted : 08/09/2016 11:10 am
DanielV
(@danielv)
Hi Erwin,
I had a similar problem with no good solution. But a hint.
I guess the problem depends on the form. An overhang.
And the problem is boosted by cooling.
First idea:
Please try to rotate the model by 180°.
The MK2 printhead will blow from the opposite side and perhaps decrease the problem.
Second Idea:
Try turning of cooling. Perhaps this will effect something, hich will guide you in the right direction.
Greetings, Daniel
Posted : 08/09/2016 11:23 am
esterne
(@esterne)
Hi there Daniel,
I will try turning it 180' tonight.
It is definitely the overhang behind the front feet that is the issue.
But other overhangs and bridges work out great. The whistle as an example.
I haven't tried to print the dragon yet. I assumed if the frog fails then so would the dragon.
What has me stumped is that a stock machine with the stock G-code ( which seems to work for everyone else ), just doesn't work for me.
How big an effect does environmental differences have?
The room where my printer is is quite warm. Between 26 and 30 degrees centigrade.
Also, I'm at 1400m above sea level.
Would this affect it ?
Posted : 08/09/2016 11:39 am
DanielV
(@danielv)
Hi there Daniel,
I'm sorry, I really don't know exactly what has to be cool, and what has to be warm. But I have some thougts made some observations.
- a warm environment seems to be good. That's why i'm operating my mk2 inside a cabinet.
- draft is evil. In all case. I causes welding and so the object lift from the bed. Another reason why my printer is in a cabinet 🙂
- I print PLA with cooling. ABS completely without. Because of the same problem like this. I think, that the problem can be reduced without cooling.
It would be nice to know what causes the material to warp up. Especially in areas with overhang. i would really like to know 🙂
Posted : 08/09/2016 12:01 pm
David T.
(@david-t)
ABS warps because of thermal expansion. The object needs to coold down equally in all volume, if possible. So don't use cooling fan while printing from ABS.
PLA warps because it is sticky. It needs to cool down as fast as possible. Using of cooling fan while printing from PLA is highly recommended.
Posted : 08/09/2016 1:16 pm
DanielV
(@danielv)
so i'm doing right.
"I print PLA with cooling. ABS completely without."
Thanks for verifying. 🙂
Posted : 08/09/2016 1:25 pm
Davide
(@davide-2)
hi,
I have the same problem, even on other models, you have found a solution?
thanks
Posted : 02/01/2017 12:44 am
david.b14
(@david-b14)
Can you try the following.
1) Print the Marvin on the SD card.
2) Try a different filament.
Posted : 02/01/2017 2:34 am
Davide
(@davide-2)
I printed marvin and it came out perfectly, the problem happens in objects that have inclined parts beyond a certain angle, like the legs of the frog, without supports
Posted : 02/01/2017 11:12 am
david.b14
(@david-b14)
I printed the tree frog 3 times as part of gifts with a non Prusa filament, here was the outcome:
1st time: Full speed, came out perfect.
2cnd attempt: Full speed, layer shift happened when the legs come together with the body, I think.
3rd attempt: Time crunch, printed at 70% speed until the legs met the body, then bumped the speed to 100%. Success.
I've had the same thing happen using the filaments from Prusa for different 3D prints.
For me the variable seems to be printing speed when the 3D object has tricky parts. It would be cool if the slicer could add a beep to your 3D during the tricky parts. Even better would be the ability to slow down the print at certain layers of the 3D object.
Posted : 02/01/2017 11:27 am
mavu
 mavu
(@mavu)
I have similar issues, and reducing the speed live during print helps.
But I'd really like to know why not everyone seems to have this problem. even you had a successfull first print of the frog, before the fail.
puzzling.
Also would like to know if a modified fan duct could help.
Posted : 02/01/2017 12:49 pm
JeffJordan
(@jeffjordan)
Member Moderator
please check out this version.
it takes about 40 minutes to print here, without any modifications of fan duct or else... no messing around with the print speed.
but you need to make sure that your z-live adjustment is right and your PEI-sheet is clean and free of any fingerprints or so.
ps. i use acetone containing nail polish remover for that.
Posted : 02/01/2017 8:31 pm
mavu
 mavu
(@mavu)
Thanks! I'll print that tomorow, very interested to see if that will curl.
Posted : 02/01/2017 10:51 pm
mavu
 mavu
(@mavu)
I just printed your presliced treefrog, and it printed well, the (overhang) belly is perfect, the only place where I can see slight imperfections is the frogs right leg, where the overhang is. The left one is perfect, the right one still nearly perfect, but there is a visible difference. But that's nitpicking on a very high level.
So. curious. I wonder how David's frog will come out.
Those are steep overhangs and printed fine with the same filament where I have problems with my Slic3r sliced prints.
Maybe I'll try slicing the treefrog with my slicer and settings, and see how that comes out.
Could you give me a rough overview of the S3D settings you used? like speed, layerheight and perimeters? (and what ever else you think is important to get this model right.)
Posted : 03/01/2017 12:44 pm
JeffJordan
(@jeffjordan)
Member Moderator
hi marco.v
thank's for the positive feedback.
the gcode was generated with philipp.m's settings that you can find here: http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/simplify3d-print-settings-august-30-2016--t938-s100.html#p13314 .
Posted : 03/01/2017 5:35 pm
PJR
 PJR
(@pjr)
Strangely, I too am just printing a tree frog.
I haven't quite gotten the settings correct yet (and apologies for the poor photo...)
Peter
Posted : 03/01/2017 10:42 pm
mavu
 mavu
(@mavu)
Peter
You tease!
Curious when I'll get my next package from Prusa 😛
Posted : 03/01/2017 11:04 pm
JeffJordan
(@jeffjordan)
Member Moderator
curious, i've seen a two color version of this frog at thingiverse and immediately was tempted to order a multi material kit :D.
but i'm going to wait until the teething problems are sort out.
:mrgreen:
@peter: is the white box at the right rear of your printbed some kind of waste bin for the filament, when operating with the multi material upgrade ?
does the printer have to change the filament 4 times at every layer ?
Posted : 04/01/2017 12:40 am
Page 1 / 2
