Need Some Help, I have no idea?
richard.e2
(@richard-e2)
I have two MK2's
Printer 1 when you select print from SD or USB it will wait for the temps to rise to set-points and then will start bed level & print etc.
Printer 2 when you select print from SD or USB instantly starts to bed level & print etc. and does not wait for temps to rise to set-points?
Tested with same SD card on both printers, both printers running latest firmware and was re-flashed to double check?
What i am i missing?
Thanks...
Respondido : 29/07/2016 8:31 pm
Cipis
(@cipis)
Miembro
Re: Need Some Help, I have no idea?
Are you sure that you tested identical g-code file on the both printers?
(btw. bundled sample Adalinda gcode isnt created correctly - it doesnt wait till proper temperatures are reached)
Respondido : 29/07/2016 8:44 pm
andersonta
(@andersonta)
Can you copy the start of the gcode you are running? I'd double check that you are indeed running the same gcode on both, as Roman said.
Respondido : 29/07/2016 8:46 pm
richard.e2
(@richard-e2)
Same G Code same file same SD card two different results, does not matter what file you print never waits for temp start? I am totally lost?
I can get round it by doing pre heat, but its strange...
Respondido : 29/07/2016 8:49 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re-run V2Calibration GCode on both printers.
I think there is a setting within that which may fix your problem.
Peter
Respondido : 29/07/2016 10:29 pm
richard.e2
(@richard-e2)
Well today, turned the printer on, with the same file & SD card that i left in it lat night and its now fine... lol no idea why...
Maybe it just needed a rest...
Respondido : 30/07/2016 1:10 pm
