Need Some Help, I have no idea?
I have two MK2's
Printer 1 when you select print from SD or USB it will wait for the temps to rise to set-points and then will start bed level & print etc.
Printer 2 when you select print from SD or USB instantly starts to bed level & print etc. and does not wait for temps to rise to set-points?
Tested with same SD card on both printers, both printers running latest firmware and was re-flashed to double check?
What i am i missing?
Thanks...
Re: Need Some Help, I have no idea?
Are you sure that you tested identical g-code file on the both printers?
(btw. bundled sample Adalinda gcode isnt created correctly - it doesnt wait till proper temperatures are reached)
Can you copy the start of the gcode you are running? I'd double check that you are indeed running the same gcode on both, as Roman said.
Same G Code same file same SD card two different results, does not matter what file you print never waits for temp start? I am totally lost?
I can get round it by doing pre heat, but its strange...
Re-run V2Calibration GCode on both printers.
I think there is a setting within that which may fix your problem.
Peter
Well today, turned the printer on, with the same file & SD card that i left in it lat night and its now fine... lol no idea why...
Maybe it just needed a rest...
