NEED HELP
trevor.m
(@trevor-m)
NEED HELP
Hey so, not sure if I have to connect the printer to usb or what my issue is, but my printer won't turn on, there is an electrical smell from the power supply as per most power supplies bit there is no sound no motor noise or LCD function. I'm kinda in panic-mode right now and I am wondering inf anyone can try to walk me through diagnosing my issue.
EDIT: I can see a green LED on the RamBo so I know it's getting power
EDIT2: I plugged in a usb cable an it recognized the printer. I'm thinking that it is the LCD?, but they are on the correct ports
Veröffentlicht : 20/01/2017 6:21 am
David T.
(@david-t)
Re: NEED HELP
Check again LCD cables and connectors.
Veröffentlicht : 20/01/2017 9:28 am
Re: NEED HELP
the ribbon cables ate polarised at one end.
at the other end make sure that cable 1 goes to connector 1 and that the coloured wire is at the pin 10 end of the connector
Veröffentlicht : 20/01/2017 10:26 am
