MK2 probe protector too big?
mavu
 mavu
(@mavu)
I just printed the MK2 P.I.N.D.A. PROTECTOR from here http://www.prusa3d.com/downloads/others/mk2_probe_protector.zip
And it doesnt fit, because the hole/threads are too big. I can put it on and off without even touching the threads on the probe.
Does anyone know if this STL is maybe for an older, thicker probe?
Or did I download the wrong file?
Opublikowany : 01/12/2016 4:18 pm
christophe.p
(@christophe-p)
Member Moderator
Re: MK2 probe protector too big?
Hi Marco,
you can try my design, available here: http://www.thingiverse.com/thing:1617374
In this case you will have to make the thread using a threaded pole or a bolt.
And be sure to use ABS, my version is wider then closer to the extruder, so heat resistant material is mandatory.
I'm like Jon Snow, I know nothing.
Opublikowany : 01/12/2016 4:57 pm
mavu
 mavu
(@mavu)
Hi Marco,
Thanks for the reply, but I don't have ABS available, I was printing it in PETG, which apparently has "similar" heat resistance, whatever that means. I was unable to find out, if PETG can actually be used for parts close to the extruder, so This would have been an experiment.
If it would fit 🙂
You don't happen to have the measurements of your probe? Then I could compare it with mine to find out if its smaller.
Opublikowany : 01/12/2016 5:04 pm
christophe.p
(@christophe-p)
Member Moderator
Well I'm not close to my printer right now but AFAIK, there is only one size for the PINDA probe (M8).
Opublikowany : 01/12/2016 5:12 pm
sean.h2
(@sean-h2)
Mine's too big too. I folded a papertowel in half & screwed it on over that, and trimmed off the excess papertowel. been working fine for a few months now.
Opublikowany : 01/12/2016 5:44 pm
mavu
 mavu
(@mavu)
Ok, i'll dig up some M8 and see if it fits.
Ok! thanks, so one vote for "nothing wrong with my calibration".
I think I'll do the same, but maybe we can get someones attention from Prusa to check the pinda protector stl.
Opublikowany : 01/12/2016 6:51 pm
christophe.p
(@christophe-p)
Member Moderator
You can also experiment with various slicer parameters, threaded part result can vary a lot depending of these parameters, due to the sharp angle of the threads.
Opublikowany : 02/12/2016 9:50 am
Carsten
(@carsten-2)
Just run also into that. It just flaps in the breeze.
Who designed that part which we can officially download from prusa3d?
Did my own now.
Carsten
My Prints: https://www.prusaprinters.org/social/15695-carsten/prints
My Employer: https://make-magazin.de
Opublikowany : 06/12/2016 4:46 pm
mavu
 mavu
(@mavu)
Did my own now.
Carsten
Could you put yours on thingiverse or somewhere?
btw: I think I own your book, nice work 🙂
Opublikowany : 06/12/2016 9:08 pm
Nick
 Nick
(@nick-19)
I think I read that the Orange parts that Prusa supply are PETG and the black are ABS. not sure why the difference, maybe they are easier to print.. I have used PETG to print my replacement parts so far, so should be fine.
I also printed the Pinda from the Prusa web site... 3 times at .2, .1 and even .05.. none fitted although one fitted an old pen I had lying around so use that to tap the desk occasionally.
Opublikowany : 06/12/2016 9:17 pm
JohnOCFII
(@johnocfii)
Other way around. The orange parts are ABS, the black are either PET or PETG (I forget which).
John
Opublikowany : 06/12/2016 9:41 pm
Carsten
(@carsten-2)
You think you have it? 😉
I will put some more Blend/STL Files online to thingieverse but here it is. http://www.thingiverse.com/thing:1945892
I have a spool holder with integrated filament guide, a protector for the X axis motor cables and hearing holders for the bed, all nothing new but interesting (I think) for Blender users. Stay tuned.
Carsten
PS: Somehow the PINDA is not quite M8, my M8 bolts hardly fit into my Pinda Protector, so I did a scaling only to find that than it is too loose on PINDA. So I printed it 4 times including the "original" 😡
Opublikowany : 06/12/2016 11:10 pm
mavu
 mavu
(@mavu)
Yes, I can't find it currently 🙂
Thanks!
Opublikowany : 06/12/2016 11:48 pm
Thrice
(@thrice)
I having the same issues printing the protector listed on the the prusa site. Its way too big, unless this was meant for a larger probe that had ben replaced. I can slip it on without even screwing it in, infact it has quite a bit of play and wont hold at all. I printed it in ABS and thought i might be shrinkage due to the material ,but stubbled on to this thread.
Opublikowany : 09/01/2017 7:20 pm
christophe.p
(@christophe-p)
Member Moderator
Actually, that's just the opposite, Orange ABS and black PETG. That's why you can glue borken PINDA support with acetone as a temporary workaround if you encounter this issue.
Opublikowany : 09/01/2017 9:49 pm
patrizio.b
(@patrizio-b)
Same here, scale it to 96% and it will be perfect.
Opublikowany : 10/01/2017 8:06 pm
christophe.p
(@christophe-p)
Member Moderator
[quote="carsten.w2"
PS: Somehow the PINDA is not quite M8, my M8 bolts hardly fit into my Pinda Protector, so I did a scaling only to find that than it is too loose on PINDA. So I printed it 4 times including the "original" :x[/quote]
Yuo need to use a ISO metric profile M8x1 thread model, Fusion 360 can do it.
Opublikowany : 10/01/2017 8:10 pm
Carsten
(@carsten-2)
Urgh! Did not expect a M8x1 there! Stupid me.
Carsten
Opublikowany : 11/01/2017 10:44 am
