Mk2 doesn't print well V2calibration
I've just finished mounting my i3 MK2 and I tried to run the V2calibration gcode, but every time it seems like the left part of the print is ok, but when it goes to the right the filament doesn't attach to the surface... I followed all the tips in the video and all the calibrations seems to be ok.
Thank you
Re: Mk2 doesn't print well V2calibration
Does your Y axis rods sit all the way down in the metal frame?
Me on MyMiniFactory!
Me on Instagram
3D Printing Live Feeds
Prusa MK2 Usergroup Slack Live Chat
Unofficial live chat by users for users.
I think they do, but I checked that to be sure. Then I tried to run the CalibrationXYZ tool and it writes in the log:
Invalid bed correction matrix. Shift out of range.
Invalid bed correction matrix. Resetting to identity.
Please measure distance between the bed and top edge of Z frame on both sides (left and right). Should be the same. Then check if Y rods (or Y lines of the bed) are perpendicular to X rods.
