MK2 and OctoPrint: Incomplete Prints and Full RX Buffer
devilhunter
(@devilhunter)
It seems like Linear Advance is too much for the current MK2 to haandle, at least over OctoPrint. The fix from last time does not work so well anymore.
I'm getting a lot of "Full RX Buffer" and "Printer sent 'start' while printing. External reset?" on two machines, one connected to a Rapi 3 and one connected to a NUC with OctoPrint.
From the Drivers Page, it seems like they disabled LA again on the recent MK3 firmwares, and fixed a lot of OctoPrint Bugs.
https://www.prusa3d.com/drivers/
Does the MK2 get some love, too?
I have to go down to 3.0.11 again until this is permanently fixed.
Edit: before i downgrade to a older FW again, can Linear Advance be switched off entirely?
Is removing M900 from filament gcode working?
Edit 2:
M900 K0 seems to disable it in Marlin, but i'm not sure about if it works on the MK2.
Recv: okSend: N106737 G1 X110.773 Y51.761 E0.02092*104Recv: okSend: N106738 G1 X110.718 Y51.618 E0.00366*111Recv: Full RX BufferRecv: Error:No Line Number with checksum, Last Line: 106732Send: N106739 G1 X110.736 Y51.148 E0.01125*100Recv: okSend: N106740 G1 X110.853 Y49.608 E0.03695*98Recv: Full RX BufferRecv: okSend: N106741 G1 X110.970 Y48.813 E0.01923*102Recv: okSend: N106742 G1 X111.127 Y47.969 E0.02055*102Recv: Full RX BufferRecv: Error:checksum mismatch, Last Line: 106734Recv: Resend: 106735Send: N106735 G1 X110.856 Y52.723 E0.02653*108Recv: okSend: N106736 G1 X110.862 Y52.631 E0.00222*106Recv: okSend: N106737 G1 X110.773 Y51.761 E0.02092*104Recv: Error:No Line Number with checksum, Last Line: 106734Send: N106738 G1 X110.718 Y51.618 E0.00366*111Recv: okSend: N106739 G1 X110.736 Y51.148 E0.01125*100Recv: Full RX BufferRecv: okSend: N106740 G1 X110.853 Y49.608 E0.03695*98Recv: echo: cold extrusion preventedRecv: okSend: N106741 G1 X110.970 Y48.813 E0.01923*102Recv: Error:Line Number is not Last Line Number+1, Last Line: 106737Recv: Resend: 106738Send: N106738 G1 X110.718 Y51.618 E0.00366*111Recv: okSend: N106739 G1 X110.736 Y51.148 E0.01125*100Recv: startPrinter sent 'start' while printing. External reset? Aborting job since printer lost state.Changing monitoring state from 'Printing' to 'Operational'Recv: echo:echo: Last Updated: Nov 12 2017 11:07:38 | Author: (none, default config)
Respondido : 21/01/2018 6:11 pm
