Live Z Adjust Discrepency
prusayo
(@prusayo)
I noticed when printing if I go to the Live Z Adjust section it says 0.000mm. Only when I turn the knob does it display the actual z axis number, in my case -.5 something. Is that supposed to be like that? I am using 3.0.0 driver.
Publié : 06/06/2016 6:30 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Live Z Adjust Discrepency
Sounds like a (possibly known) fault in that version of firmware.
You should upgrade to 3.0.1 and try again (check out Michal's post here: http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/i3mk2-set-up-and-calibration-t987.html#p7404 )
Peter
Publié : 06/06/2016 8:02 am
Nicolas
(@nicolas-6)
I'm using the 3.0.1 firmeware and I've got the same behaviour once. Other times were fine.
Publié : 06/06/2016 9:42 am
PJR
 PJR
(@pjr)
Nicholas
That seems very strange. Computer software should behave in a more consistent manner.
When it happened to you, was it the first time after upgrading the firmware? If so, it could have been due to differences in stored variables.
Peter
Publié : 06/06/2016 10:29 am
Nicolas
(@nicolas-6)
No, I have never used 3.0 firmeware.
I think it happened after a reboot, but I'm not sure of that.
If I find a way to reproduce the glitch, I'll post it.
But I will not have access to the printer this week.
Publié : 06/06/2016 11:24 am
Josef Průša
(@josef-prusa)
Membre Admin
Hi guys, I checked and it is present in all firmwares. We will fix it for 3.0.2.
If you have any other little comments/bugs in the FW let us know, so we can push it into 3.0.2
Founder and owner / Majitel a zakladatel
Publié : 06/06/2016 2:54 pm
todd.m2
(@todd-m2)
Can you point me to instruction for updating the firmware and the latest version?
Publié : 06/06/2016 3:35 pm
