Led on bed not working
joseph.f3
(@joseph-f3)
anybody know why the led on the bed doesn't light up? it did when I first ran it about 1 week ago but now not anymore
Opublikowany : 23/05/2017 12:09 am
Bill
 Bill
(@bill-3)
Re: Led on bed not working
May seem like a dumb question, but since you did not mention it... Is the bed heating? If so, may be that the LED went bad or has a cold solder joint. If there is heat, it should not affect anything. But, I personally do like the feedback of the LED. I especially like it when I am monitoring remotely with octoprint.
Opublikowany : 23/05/2017 8:23 am
slayer1551
(@slayer1551)
Mine did the same. Have you checked the connector on the Rambo? Mine was fried so had to solder it to the back
Opublikowany : 24/05/2017 2:37 am
joseph.f3
(@joseph-f3)
bed heats up and everything seem fine but the led does not work
Opublikowany : 29/05/2017 4:54 pm
Is the polarity correct?
+ & - reversed?
Opublikowany : 29/05/2017 7:19 pm
joseph.f3
(@joseph-f3)
its all pre wired from the factory you just plug it in. Prusa sent me another heat bed but its the same thing, everything works the bed heats up prints nice but no led. Maybe they have a bunch of bad leds from the supplier the bummer is the original prusa i3 mk2s is not cheap I hope we can get this sorted out
Opublikowany : 30/05/2017 8:10 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
I have noticed that some bed cables have been soldered incorrectly (red stripe on negative). One of my beds is like this. The Mk42 bed, having only a single LED needs to have correct polarity.
Other beds I have used have a pair of LEDs wired in opposite direction so one will always work.
There was also a instance reported here a while ago of the LED resistor being poorly soldered and not connected. But that was only one single instance.
Peter
Opublikowany : 30/05/2017 8:22 pm
JeffJordan
(@jeffjordan)
Member Moderator
.... so simply turn around the polarity. it's only relevant for the led. its completely irrelevant for the heating.
Opublikowany : 30/05/2017 8:44 pm
