[Closed] Lead-screw specifications
Stránka 2 / 2
spark
(@spark)
Re: Lead-screw specifications
During a deep check of my MK2S to fix my wobble issue, ...
Can you link to your post on your wobble issues? Lead screw having slight bit of skew causing tip to rotate axially off center (wobble?) is not a huge problem for print accuracy as X-location is provided by vertical linear rods and bearings. I'm not going into wobble as that isn't this thread's topic. But just quickly, you can adjust where the lead-screw points by moving the lead-screw nut within the slack of it's mounting screws. I've solved my z-axis-top rattle by this method. There should be nothing loose on your printer, ever. All moving parts should be tight but lubricated. 😉
MK2S kit owner since 8/15/2017
Napsal : 03/01/2018 5:55 pm
Bigdogbro1
(@bigdogbro1)
Has anyone tried the anti-backlash type lead screw nuts on the Z-axis?
Something like these:
https://www.smw3d.com/acme-anti-backlash-nut/
Not sure they will fit the end brackets but thought I'd ask.
MK3 Kit, Designed, built 4x4 CNC Plasma Cutting Table, Motorcycles Bigdogbro's Adventures
http://www.youtube.com/channel/UC5djrxBeeOKB9_6rHnn6G8A
Napsal : 21/01/2018 2:09 pm
john.n13
(@john-n13)
This supplier doesn't seem to have versions for trapezoidal threads, only ACME. Perhaps an EU supplier will?
Napsal : 21/01/2018 2:57 pm
bulidesber.s
(@bulidesber-s)
Is this right?
Lead Screw & Nut
My stepper motor site: skysmotor.com
Napsal : 27/06/2018 9:22 am
MTJC
 MTJC
(@mtjc)
Martin
8mm diameter, 8mm pitch, 4 threads
Peter
What does "4 threads" mean?
Napsal : 16/02/2019 6:04 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Martin
Peter
Rather than having a single thread of 2mm pitch, there are 4 threads running in parallel, each with an 8mm pitch. AKA four-start.
Peter
Napsal : 16/02/2019 11:34 am
MTJC
 MTJC
(@mtjc)
Martin
Peter
Peter
Ahh, ofc. Thank you for explaination PJR! 😀
Napsal : 16/02/2019 1:37 pm
Mattchew
(@mattchew)
RE: Lead-screw specifications
Pololu has copper alloy ones Tr8×8(P2).
https://www.pololu.com/product/2688
Napsal : 21/01/2020 7:44 pm
Stránka 2 / 2
