LCD Screen cant read SD cards anymore
Rakku
(@rakku)
Suddenly out of the blue, my SD Cards are not being read by the LCD screen anymore.
It registers when a SD card gets put in, but if I look for the card, it says no sd card.
Doesnt matter which SD card I use, the cards work on the computer and everywhere else.
I still have to swap out cables to check if they are ok, but why shouldnt they be?
Any solution?
Publié : 18/06/2017 1:47 pm
christophe.p
(@christophe-p)
Membre Moderator
Re: LCD Screen cant read SD cards anymore
Hi Ario,
it's possible that during a sd format, you changed the partition table style. I remember that my test showed using GPT is not supported by the SD Card reader. So you should double check and ensure that MBR is used instead.
Otherwise swapping the cable would be a good way to see if a ribbon have been damaged, you are right to try that.
I'm like Jon Snow, I know nothing.
Publié : 19/06/2017 2:08 pm
phil.s2
(@phil-s2)
hi - it could be a really simple problem - a lot of the time it is
unless you have zapped it with static - or unplugged it without demounting it then try cleaning it
a lot of the time the contacts get dirty and the card is failed to be read
see my post here https://best3dprinter.stan-tech.com/my-3d-printers-not-reading-my-sd-card-help
good luck sorting it out
phil
helping others with 3d printer problems
building 3d printers
showing you can repair almost anything with a 3d printer and innovation - well, design!!
www.best3dprinter.stan-tech.com
Publié : 20/06/2017 11:47 am
