Layers not bonding part way through a print
jim.h
(@jim-h)
The images probably describe it better than I can, but recently I've been having a problem where the print will be fine, and then suddenly (usually around 12 hours in) the layer adhesion will fail. There are no layer shifts - the layers just stop sticking together.
Any ideas what would be causing this?
Veröffentlicht : 03/12/2017 1:28 pm
jim.h
(@jim-h)
Re: Layers not bonding part way through a print
Some more info:
[*] printing in PLA.
[*] Same gcode has done this twice at different points in the print
[*] Ambient temperature could be dropping overnight
[*] print settings are default PLA settings for i3mk2
Veröffentlicht : 03/12/2017 2:24 pm
slippyr4
(@slippyr4)
Underextrusion.
Either your filament got snagged, or your stepper driver overheated.
Veröffentlicht : 03/12/2017 8:19 pm
AJS
 AJS
(@ajs)
Or:
The hob pulley is loose from the stepper motor
or
You have a clog in your extruder
or
The tension is set too tight on your extruder
or
bad extruder calibration
or
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Veröffentlicht : 05/12/2017 2:22 am
