Layer Delamination
james.m21
(@james-m21)
Layer Delamination
I am a noob to 3D but love my Prusa and have had much success so far. A couple of times -- once using Slic3R and once using Cura, I have run into a situation where the layers are fine until a certain stage of the job and then the layers suddenly get sloppy and lack cohesion. Attached is a photo. What am I doing wrong? stl file was pulled from Thingiverse and has .15mm layer height and 35% infill. Thanks for any suggestions.
Veröffentlicht : 09/06/2017 9:42 pm
Nigel
(@nigel)
Re: Layer Delamination
Raise your filament temp in 5 deg steps.
Nigel
Veröffentlicht : 10/06/2017 6:10 am
james.m21
(@james-m21)
Thank you. I will try that. Oddly, I imported the stl file to Slic3r and it printed perfectly. The default settings must have been better. The other thing I noticed last night on a different print job was that sometimes the filament on the spool gets tangled and the spool essentially gets stuck. Wonder if that had anything to do with it.
Veröffentlicht : 10/06/2017 3:12 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Absolutely. This is a common issue when you either purchase filament that have not been carefully wound (as I have on occasion) or when you don't keep hold of the end when unloading...
Peter
Veröffentlicht : 10/06/2017 4:47 pm
