Incorrect idle temperature reading
david.z9
(@david-z9)
I have noticed that the idle temperature reading on my Prusa MK2S is 34 C instead of 21-22 C (on both bed and extruder).
I don't know for sure, but I feel like it used to say 21-22 C before and this is something I noticed recently.
Has anyone experienced this? Is this an early sign of a potential problem?
The printer is working fine, but I have not explicitly measured any temperatures when it's hot enough to print.
Thanks for any help! Great printer by the way.
Postato : 14/03/2018 12:17 am
Re: Incorrect idle temperature reading
they should read close to ambient temperature... whatever that is in your area.
if they showed less than 15 centigrade it may indicate a broken wire on the thermistor
if they showed very high temperatures, that could indicate a short circuit! on the thermistor wires
keep an eye on it, but don't worry at the moment
might be prudent to order a spare of each
however if you are going to get spares, consider also the two fans, a pinda, and some cable for the heatbed... these have all failed{ at different times) on my oldest prusa... which was originally a Mk1
Postato : 14/03/2018 1:07 am
Blackbird351
(@blackbird351)
I have the same issue on my MKs2. It reads 9c higher than room temp. I have a MK3 sitting right next to it that reads correct.
Interestingly, if I unplug the thermistor from the board, the temp reading drops to the correct room temp.
Both thermistors read the same at room temp.
I plugged in a spare thermistor, same reading.
unplugged both from the board and both readings dropped to room temp. Used a hair dryer and warmed the board up and both readings went up.
Used dust off and dropped both temps.
I think there is an issue with the temperature sensors on the board, or the firmware (but I would think everyone would have the same problem)
The sensors are somewhere between the thermistor plugs and the square processor chip.
I realize that the temps will vary a little, but 9c seems like too much.
Postato : 14/03/2018 8:07 pm
not all Mk3's read high at idle[attachment=0]20180314_212057[1].jpg[/attachment]
Postato : 14/03/2018 10:23 pm
Blackbird351
(@blackbird351)
I agree. My MK3 reads perfect according to my IR camera.
Postato : 16/03/2018 9:01 pm
