Impossible to do the calibration after upgrading the firmware ! HELP
Seb
 Seb
(@seb-5)
Hello at all,
I'm writing today, my first post because I do not know what to do ...
Here is my story :
  • When I received the printer, I had the 3.0.9 firmware in it. After mounting it, I done the all calibration and all was ok.
  • After several months, the prints began to be more and more unstable (the PLA no sticked correctly, the object was no longer straight) ...
  • So I tested lot of parameters in Slir3r software, but no really improvement.
  • After that, I seen on Prusa web site that the firmware 3.0.10 was released.
  • I uploaded the firmware 3.0.10 to the printer and I had redo a calibration XYZ. But at this moment, it failed and I almost lost the bed when the extruder began to do a hole to the bed.
  • At this time, I restarted the calibration with lot of attention but it failed a second time.
  • I discovered a way to do a factory reset (all parameters / eeprom are deleted).
  • After that, I restarted the calibration but it failed with another message, and I decided to change the height of the PINDA.
  • After that, I seen on the Pusa Web site a new firmware 3.0.11.
  • I uploaded the firmware, done a reset factory, and restarted the calibration.
  • I successed after 5 attempt.
  • I printed my work (after 2 weeks without success) but the result was not good because I had the impression that the calibration was not taken in account.
  • So I decided to see a new time the video of Prusa for the calibration of the printer. I respected strictly the alignment of PINDA.
  • And I done a factory reset and I restarted the calibration.
  • It failed 🙁
  • So I downgrade to 3.0.10, it failed
  • So I downgrade to 3.0.09, it failed
  • So I downgrade to 3.0.08, it failed
  • Same message "XYZ calibration failed. Please consult the manual.".
  • I do not know what to do ....
    If someone can help me, thanks in advance ...
    (If you need photo, video, don't hesitate).
    Best regards.
    Postato : 07/06/2017 10:14 am
