I think my print bed is warped?
douglass.l
(@douglass-l)
Starting the second week printing almost full time.
Seems the bed sensor is touchy at locations 5 6 8 and 9 when counting left to right starting at the front. 1/8 th turn either direction will not work (in the sweet spot for now).
Used a machinist angle to test the bed and found that it slopes off low on the right rear by one to two widths of paper.
I took it apart and back together, low on the right back six boxes, it sits correctly on a flat surface and it is seated all the up into the z plate. The y rods are fully seated on all four corners.
Now that I have a sweet spot for the sensor the mesh bed leveling is working, but should this be low or should it be flat.
Postato : 23/12/2016 5:29 am
